Survey: Snow Tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric, Sep 26, 2000.
  1. Eric
    Eric Registered Member
    Mar 21, 2000
    86
    Currently run BFG AT KO's for all season tires. Thinking of putting some BFG Mud Terrains on for the winter.
    Understand that the AT KO's do not self-clean well in mud.
    Which is better in the snow: AT KO or Mud Terrains
    One eyed super fly- watch out!
    86 K5 Blazer
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I would think the AT would do better on snowy roads, but the MT would do better in really deep snow. The AT would do better on slick and icy roads.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The A/Ts will be way better in on-road mix of snow and ice. If you are running trails with deep snow the Mud tires may have an advantage. Mud tires are dangerous on ice.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I agree with Blazer1970.
    What I am considering doing is siping some MT's for all-year use since they look so much better and would then be almost an ideal all-year, all-use tire. I would like to hear of somebody's experience with this, though.
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  5. Eric
    Mar 21, 2000
    86
    Thanks for the info guys. Looks like my BFG AT KO's will be fine for the winter. Leaves money for other good stuff!!
    One last question:
    What about in the sand? BFG AT KO's or BFG Mud Terrains? What tire pressure should be used?
    86 K5 Blazer
  6. Scoobydoo
    Scoobydoo 1/2 ton status
    Jun 9, 2000
    244
    Phoenix / Peoria ARIZONA. (75thAve/DeerValley)
    In sand, I bleed them down to between 8 and 12 psi
  7. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,791
    100
    Paducah, KY
    Just thought I would throw this in. Lots of people are confused about tires in the winter, so I think I will clear it up a little. I'm from Michigan, and learned this stuff that hard way. You have to think of the roads in winter like REALLY, REALLY WET summer roads. Deep snow you have to treat like thick mud.
    -AT's are great onroad during the winter and in very light snow, nothing deeper than an inch or three. Snow bonds to itself, so when the little crevices in the AT treads pack up with snow, you are actually getting traction from all the snow in the treads "gripping" the snow on the ground.
    -On ice, AT's are better because they have more tread to get what little traction is available.
    -In deep snow, AT's are no good. Just like if you tried to drive your AT clad truck into a gumbo mud pit. You wouldn't make it very far. No tread to shovel through the snow and toss it out.
    -MT's onroad in the winter are not that great. Not enough tread hitting the road to take advantage of the limited traction. Lots of sliding. I know this from experience.
    -On ice, they are worse than in heavy rain.
    -In deep snow, MT's rock! All the big lugs dig into the snow and toss it out, so you are always getting traction. Kinda like mud, but with less stickiness.
    This is from my personal experiences, but I think it is pretty accurate. Hope this helps.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Gibson, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's [​IMG]
  8. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
  9. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Have had three different sets of BFG A/T's on three different Blazers..........and they overall are a great tire in snow. Facts of snow..........it melts, then usually freezes below the surface, then melts again, etc., and these tires work well on the ice.
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>http:// www.blazzinor.coloradok5.com
