Survey
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James, Oct 25, 2000.
  1. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    I was told never to use RTV sealant on tranny pan gaskets? Well I have always used RTV sealant. Who does and who doesn't. I was told the tranny fluid eats it up anyways?
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I've always done it and never had a problem with it.
    90K5
  3. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    i ALWAYS use lots of schmutz on any gasket!!! i like to know that even if it doesn't make a difference i know that it's there... the best kind i've found to use is the gold stuff!!!it works AWESOME on header gaskets. this stuff has a high temp. tolerance and works great.. the only place that i don't use it is on like intake gaskets and such because the blue goo doesn't show all the dirt and stains as the gold does..
    DRIVE IT LIKE YOU STOLE IT
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Have never used it on tranny pan gasket. Had a 69 corvette that when I bought it trans was leaking out of pan because of R.T.V. If you just snug bolts down evenly you should have no problems. Also use cork gasket not paper, seems cork seal better. Some cheaper no name filters come with paper gaskets.
  5. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    RTV is awesome, I use it for practically everything. My trnasfer case was leaking on a seam. Did not even take it apart, just cleaned it up real well and put some on the outside. Has been like that for ages and not one more leak. If you do use it don't put so much on that it breaks off inside, that is bad.
    Good luck
    Go heavy or Go home[​IMG]
  6. K2500
    K2500 Registered Member
    Sep 28, 2000
    64
    Alamosa CO
    Dont take my sig. into account on this?[​IMG] Using a little RTV to help the gasket seal is good, but use to much and you have the same problem you were trying to cure. It can also go inside what you were sealing and cause all sorts of havoc. I once bought a '79 Trans-am that the knucklheads had used it on the head gaskets.[​IMG] Had cooling problems out the wazzoo. A thin film on the mating surface will help, just dont glob it on.
    If it aint leaking it aint mine [​IMG]
  7. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I personlly don't like to use RTV at all on anything, But I have and do on occation. I would rather have a gasket and a good gasket sealer instead.$.02
    blazen91
  8. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    RTV all the way. I cant remember the last time I bought a gasket.lol
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red>, it's a population control thing.</font color=blue>
  9. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    the only time I've used RTV sealant was when the molded gasket wasn't available. I've used it on waterpumps and thermostats mainly -- not really anything else.
    DMK is correct, if you use the correct gasket and tork the bolts to the proper ft/lbs, it will seal just fine.
    Thomas.
    -- '84 K5 Blazer --
    http://stoopalini.coloradok5.com/index.html
  10. James
    Jun 22, 2000
    179
    Castaic, Ca
    My problem is. I can't remember the last oil pan or tranny pan that I've had being level. After so many changes taken pan on taken pan off. The mounting surface becomes unlevel. It gets to where the gasket is just not thick enough to create a seal for the unlevel surface. Atleast I think that is the problem. Have always torqued bolts to required lbs.??? Still leaks. I don't know about other people. I've take my freaking Tranny pan on and on so many times I hate the mess. Sick and tired of cleaning tranny fluid off the garage floor. I think I'm going to spend some dough and by one with a drain bolt. Do they make a tranny pan with drain bolt?
  11. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    Yes they do make pans with drain plugs in them.
  12. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
  13. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    James,
    No RTV on the tranny pan. I use the gasket only. Make sure you torque down bolts evenly and don't over torque any of them. I just changed my tranny pan to a B & M deep pan, not too long ago, no leaks. My old tranny pan, which is still in excellent shape is not warped and has a drain plug (which helps big time when changing fluids). I was going to sell it on Ebay, unless you want it, I'll give it to you for $5. Its for a TH350. Let me know. I can send you pics.
    Boss
    http://www.boss.coloradok5.com
  14. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
  15. Boss
    2,550
    Maryland
  16. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    I dont use the RTV on the tranny pan. Use it everywhere else, but not on the tranny pan. When I bought this Blazer the person that had it before me used, now get this, clear tub and tile RTV. The whole thing leaked and some things I think leaked because it was laughing so hard at this guy for using tub and tile RTV. There were gobs of this stuff in everything. The bottom of the engine had chunks in it and partially clogging the oil pickup screen. Use the gasket that comes with the filter. Make sure that the pan sealing surface is flush. Use a small ball peen hammer to get the bolt holes flush. Torque it to spec (12 in lbs) and you wont have any problems. I also use the B & M deep pan. No problems with leaks.
  17. Glenn
    Glenn Registered Member
    87
    North Kingstown, RI/USA
    RTV is bad. If it goes inside the tranny you are all done.
  18. James
    Jun 22, 2000
    179
    Castaic, Ca
    Boss,
    I'm all over that. I have your email address. when I get into work I'll have $ order made up . If u can post your adress or u you prefer to email me its. Jay.Waltersd@cheapseatstravel.com or Jamesdwalters@yahoo.com. Let know what type of delivery is easiest and I'll call that co. for price of shipping.
    Thanks dude
