suspenison/stock spring question
Discussion in 'The Garage' started by jace71, Apr 14, 2007.
  1. jace71
    jace71 Registered Member
    Mar 17, 2007
    32
    Georgia
    Will the 4" lift off my 85 k10 fit the 75 k5?? and will the stock k5 front springs fit the 85?? I want to swap the suspension from the 85 to the 75 in case anyone is wondering
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    yes, it will swap over, one thing to look at is the rear end leaf springs. I have bought a 1/2 ton truck before with 56" rear leaf springs, and i believe most 1/2 ton trucks and blazers use 52" springs stock, so as long as the springs are 52" on both trucks, the'll swap. Also, the truck mounts the shocks different then the blazer, but it should still work if your using the stock axles. If your using the axles from the 1/2 ton truck also, then a shock mount needs to be either relocated, or a new one welded on.
