Suspension-72 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ressurection, May 16, 2000.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Pls help, the factory rivets are bad on my front mounting bracket for the drivers side front leaf spring. I'm doing a frame off resto for playing in the woods, but no racing, or heavy beatings. Should I just replace them with bolts (I'm thinking stainless), or are there aftermarket brackets that may be better? Also, is there any reason to do both sides right away? 76,000 miles. Thanks!
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If you do replace them, use grade 8 bolts, with lock washers. If the other side is not loose, I wouldn't mess with it.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yes I agree, grade 8 and I use the nylon lock style nuts, I think someone at one time refered to them as aircraft lock nuts!? Ya know the kind with a small peice of nylon inside the nut!That plus the lock washer and your secure!!
    Good luck
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
