Suspension help
Discussion in 'The Garage' started by FMJ, Feb 24, 2005.
  1. FMJ
    FMJ Registered Member
    Dec 29, 2004
    94
    Duluth, MN
    I have no idea what to do with the suspension on my truck. I'm thinking put a divorced 205 in with 4 inch shackles and ?? lift to run either 40's or 42's. I want as much flex as I can get, and I am building this truck for mud and trails and maybe some rocks. I don't know much about suspension, and some help would be greatly appreaciated.
  2. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    Well, first you need to tell us what kind of vehicle you are putting the 40's or 42's on:confused::dunno:
  3. FMJ
    Dec 29, 2004
    94
    Duluth, MN
    It'll be a longbed dodge frame, with an 80's chevy front end on it with the front fenders cut up and probably a 2 inch body lift incorporated into the new mounts. There will be no bed, just a cage. Should I just buy a 4 inch lift kit and run the 40's or would I be better off doing somthing else?
  4. jkce457
    Nov 22, 2002
    135
    Southbury, CT
    The least amount of lift possible is best for a lower center of gravity. The main reason to lift it would be for tire clearance. You won't have to worry about the rear since the bed is removed, and 4 inches should be enough in the front with some major fender trimming. I'm not sure if you will have any other clearance issues in the front since you have a hybrid set up.
  5. FMJ
    Dec 29, 2004
    94
    Duluth, MN
    Well I'd like to be able to swing the front tires around a lot without worry of rubbing. With the 4 inch springs i'd have a total of 8 inches.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's too much.
  7. FMJ
    Dec 29, 2004
    94
    Duluth, MN
    What would you suggest then.
  8. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    i run 40s with about 5" of suspension lift and 1" of body lift. I'm probably going to lose about an inch of suspension lift when I go to 52" springs up front. Anyway, low COG is always a good thing. I don't see any reason to lift a fullsize's suspension any more than 6" really... just trim the body until whatever tires you chose fit.
    j
  9. FMJ
    Dec 29, 2004
    94
    Duluth, MN
    So what size springs would i need to run to get at least 6" of lift?
