suspension kit ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wfahlgren, Feb 17, 2001.
  1. wfahlgren
    wfahlgren 1/2 ton status
    Dec 30, 2000
    157
    Northern California
    I have a 72 blazer, I want to put a 4" lift on it. What brand is the best. Super lift, Tuff country, Rough country. I want front and rear springs. Do I need to get a 4" in the front and a 6" in the back to level it out?
  2. blazercrazy
    blazercrazy Registered Member
    Feb 18, 2001
    24
    If you're gonna lift it at least 2" then replace the rear springs with lift springs. If the rear is still not level, then you can stick a helper spring in there. Do you want articulation or is it more of a daily driver? The softer the kit, the better articulation and the worse it is on the road. The rougher the kit, the harsher the ride, less articulation, but better on the road. I've had experiance with ranch hand and it was okay.
    Make sure your truck is the muddy one! [​IMG]
