suspension options
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by alec78, Jun 6, 2003.
  1. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    I'm looking at doing a 2 1/2" lift on the K5. I am doing a shackel flip on for the rear. Only question there is since there is more flex and as this is my daily driver, should I also add a sway bar for on road driving?
    On the front I'm doing a spring lift. I've priced out springs from the local spring and suspension shop for 3/4t 3 leaf. I also priced out a set of Tough Country 2 1/2" lift HD springs (via ORD of course). They price the same.
    Of course there are other upgrades I will be doing during the install (ORD HD frnt spring shackel, greasable bushings, etc), but I was wanting opinions about my plan. /forums/images/graemlins/ears.gif
    Please don't tell me to go with a taller lift, as I can't get too carried away with this.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    hey i have 38's under my 2.5in lift /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    You forgot to mention the "minor" fender trimming. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    unless you will be raising the shackle mount point in the rear a shackle flip will give you 4" lift. You using an aftermarket flip kit?
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    ORD makes a 2.5" shackle flip. ORD's shackle flip is a very good product. I would do it again if given the choice.
    It is hard to say what spring rate those 3/4 ton springs would be from the local spring shop. You can get the spring rates for a 4" lift here:
    http://coloradok5.com/springratetable.shtml
    I am sure the 2.5" springs would be simmilar.
    As to the rear being softer/harder when you flip the shackle it really isn't enough to notice. The only down side handling wise it the extra 2.5" of height /forums/images/graemlins/smirk.gif
    If you are going to be doing alot of towing or think there is too much body roll when you get it hooked up then look into a sway-bar for the rear (and maybe even a stiffer one for the front). Just make sure you put disconnects on it if you intend to wheel it (I would hope you will because you are lifting it).
