suspension problems????????
Discussion in 'The Garage' started by bear, Feb 10, 2003.
  1. bear
    bear Registered Member
    Sep 16, 2002
    31
    Georgia
    If any of you guys or gals can help me figure this out, I'd be much obliged.....the driver's side of my rig sits about 1" lower than the passenger side. I've got new 2.5" lift blocks in the rear and new 2.5" springs up front. I'm on 32" tires, and yes, I've check the air pressure. All 4 shocks were replaced recently. This is driving me nuts!!!! Any ideas?
    83 K5/305/2.5" lift/32" Firestones
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    is someone sitting in the drivers seat? /forums/images/graemlins/thumb.gif
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    most cars and trucks droop to the driver side becasue a driver is always in it. and in my case, the driver is a phat arse and makes it lean more.
    switch the springs to the other side and even them out
  4. NE-RokToy
    NE-RokToy Registered Member
    Dec 24, 2002
    39
    Omaha NE
    You said they are new springs, and as such they will take some time to break in and settle. To speed up the process take it wheeling, nothe breaks springs in faster then some good rough trails.
  5. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Body mount bushings. Check those.
  6. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I agree with all of these: body mounts, upper shackle bushings, and GO BREAK THEM IN!! /forums/images/graemlins/thumb.gif
  7. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    me too! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. bear
    Sep 16, 2002
    31
    Georgia
    thanx for the suggestions...and the Blazer sags on the driver's side even when there is no one in the driver's seat. My rig had this problem when I bought it, so I hoped that the suspension upgrades I made (shocks, springs and blocks) would fix it. So, does that leave the body mounts?
  9. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Yep.
  10. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Or a bent frame /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif I got in a wreck in my K5 once after wheeling it for years. The frame was bent just behind the steering box. When I got it repaired, the guy had it on a frame machine and straightened out the rest of the frame for me. He said it was out a little bit here and a little bit there. Afterwords, it sat straight and even the doors opened and closed better /forums/images/graemlins/laugh.gif. It still had one rear corner which sat a little lower so I pulled out the rear mount bolt, jacked it up a little, put a few fender washers in there, and bolted it back together. Good as new. /forums/images/graemlins/grin.gif Hope this helps /forums/images/graemlins/thumb.gif
    Chris /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  11. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    frame, mounts..and check the cab supports for rust...they rust out and down she goes..my dads 79 pickup sags on the drivers side cause one of the core supports collapsed due to rust!
  12. hardcore_rob
    hardcore_rob 1/2 ton status
    Dec 6, 2002
    111
    Colorado Springs, Colorado
    check to make sure the rear right block is sitting correctly. i had a similar problem, thought it was exactly where it needed to be, once it popped into place it evened everything up, plus it seemed to be the cause of the dogtracking i was experiencing. i fixed the way the leafs set on the block and i noticed that the axel was a bit off, just some things to check.
