suspension questions
Discussion in 'The Garage' started by 85burbanator, Apr 25, 2005.
  1. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    alrighty, ill be recieving my tax returns here shortly and am going to buy stuff for my blazer project. ill have about 500 or so for suspension parts. im doing a shackle flip in the rear for sure along with some tc 2.5 lift springs. im debating on 52"s up front (have some lying around) or some lift springs. im looking for around 5 inches of total lift up front (zero rate will be used to move the axle forward) and alittle more in back to prevent the sag. the truck will be street driven every once in a while, more so in the winter. are the 52's streetable up front? also if i deside to do 52"s up front what is a good shock that wont break the bank? thanks in advance
    mike
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Here's a bump for you.
    From what I've read (and because of that, it's what I'm doing as well) you must convert to crossover steering to run 52's up front, due to the axle being moved forward ~2" and due to the extra flex causing the stock front/back steering to bind up at full stuff & full droop.
