Suspension & Steering parts, What can & can't you paint?
Discussion in 'The Garage' started by MTMike, May 6, 2005.
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I'm starting my suspension/x-over project next week, so I need to know what I can and can't paint. I've read things about not painting certian steering parts & such because the metal doesn't make proper contact. I'd just be using a rattle can.
    Here's the list of the parts I have that I would like to paint:
    WFO Draglink
    WFO DLE's
    WFO Steering Arm
    WFO Pitman Arm
    DIY4x Shackles
    Dunks shakle-flip bracket
    4 Tuff Country leaf springs
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I would think everthing is paintable except the holes for the TRE's in the arms and the underside of the steering arm itself.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Paint everything after it's all assembled and installed, then you won't be able to get paint where it doesn't belong.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Don't paint the holes for the DRE's and TRE's or the two mating surfaces between the steering arm and knuckle.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Some tape and a razor works wonders .
    Mask off the mating surfaces of the steering arms , paint the rest .
    So paint don't go in the holes mask each hole and use the razor to go around the hole just enough the hole stays covered and you can't see unpainted areas when fasteners are on .
  6. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    what they said... everything but threads and the underside of the steering arm.
    j
