Suspension suggestions
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 724fishin, May 2, 2002.
  1. 724fishin
    724fishin Registered Member
    Oct 12, 2001
    20
    Antioch, CA
    I am interested in peoples input regarding a suspension for my 72 Jimmy. I want to run 35 in tires. I don't want to do a shackle flip in the rear or run blocks. I have an older style winch in the front so there is some extra weight there and I expect to have a fairly heavily loaded tool chest in the rear. I am not very worried about the street ride, it is not a daily driver. I just want it to be fairly capable off road, not extreme but not embarrasing. As always it needs to be reasonable cost wise.
    What are peoples thoughts on BDS suspensions, anyone have any experience with them?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Here is what I run, take a look at my gallery listed below and you can see what it looks like.
    Front is Rancho 4" springs
    Rear is Superlift 5 1/2" springs
    3" body lift & trimed sheetmetal
    One thing to keep in mind when buying a lift for our rigs is the pre-made spring packs are made to the weight specs of a GM PickUp. The rear of our K5 is heavyier so a 4" rear lift will sit lower than the front "saggy Butt".
    My combonation does sit just a bit higher in the rear with my hard top off but sits level with it on.
    Hope this helps.....
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i agree with the skyjacker springs. they are good but expensive, but since you dont want a flip and or blocks whjat choice is there? i dont know about the other springs. check the for sale board. skyjacker has an add in the paper today. they need 3 people. maybe mr. rick will give you an employee discount. lol thanks for the help with the mounts
    nathan
  4. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I run 35's with a SkyJacker 6" front/8" rear spring lift. Handles very well and the back end sits a little higher than the front (the 8" rear gets rid of the Blazer 'butt-sag') so your tool chest should be no problem.
    Chris
  5. ED70K5
    ED70K5 1/2 ton status
    Apr 28, 2000
    179
    Texas, USA
    I'm running 4 in. Tuff Country springs in the front and blocks in the rear. I'm gonna do the shackle flip ASAP. The ride is really soft with these springs. I'm running 33x12.50 SSRs on 15x8 Rocrawlers. I have pics posted if you want to take a looksy!
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    im running pro comp springs.i got them from 4 wheel parts wholesalers.they were 288 for thew rear.my front was already lifted but the front springs are generally cheaper than the rear.so i dont see the four springs costing more than 500 dollars.
  7. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Skyjacker Springs all the way. They are really not any more expensive than any other springs. They are high quality. I would try 6" front and rear. If you need more rear lift, try some zero rate add a leaves from ORD.
