Suspension travel and shocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hardcore, Mar 30, 2004.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Looking at building a crossmember in the rear to mount my shocks in a /\ fashion. I also am looking at purchasing the Missouri offroad setup to save myself some headaches. Either way I am going to need long shocks. The decision that I am trying to make is how long of shocks do I need. I'm going to be running a 4" Flip and 4" springs.
    Should I run shocks that are at the center of there travel when mounted up. This would give the suspension even up travel and down travel. (Ex: a 14" travel shock, 7" up,7" droop) I think the suspension would have more down travel so I'm thinking about getting slightly longer shocks so that the suspension can move down more (Ex. 15" shock 6" up, 9" droop) What is ya'll experince with suspension travel up vs travel down and where are your shocks in that travel range when sitting on flat ground?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Engineer your setup so your axle can travel up to the bumpstop, then use whatever is left for down travel.
  3. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    I'd jack the truck up at the bumper and measure how much drop you have. then you know about how much down travl you will need. I'd always give extra on the drop. /forums/images/graemlins/thumb.gif
  4. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    I thought of that but the bumpstops are supposed to keep the shock from bottoming out so I wanted to do them after I positioned the shocks. The placement of the bumpstops for 8" of lift is pretty low and will limit the flex. Given the fact that I will have a soft setup and cut fenders I probably will be able to flex the suspension to the position of the bumpstop for a 4" lift............Does that make any sense? /forums/images/graemlins/confused.gif
  5. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    That is probably the way I'll have to do it. Like you said I think I'll need more down travel than up.
    Anyone else running a similar setup?
