suspension travel ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smp, Nov 27, 2000.
  1. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    suspension travel ?\'s
    Does limiting upward travel with bumpstops limit downword travel on the other end?
    [​IMG] SMP
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Re: suspension travel ?\'s
    With a solid axle, yes, because when one side goes up, the other side has to go down and vise versa.
    Brian
    84k5
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Uh.....I'm not sure I follow. One wheel can travel up and the other doesn't necessarily has to move. Down travel is limited by the leaf-spring itself. Maybe I'm confused...anybody else?
    Michael[​IMG][​IMG]
  4. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    i am lost too, because if one side hits the bump stop that should create a new pivot point and the other side should be able to continue down until the leaf spring, shock, or other limiting factor prevents more downward travel. is this correct?
    [​IMG] SMP
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    doh, now I'm confused, I didn't think about it pivoting.
    Brian
    84k5
  6. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    They shouldn't effect droop on the other end at all. Bump stops only effect the upward travel of the axle.
