suspinsion questions
Discussion in 'The Garage' started by huntinfool79, Nov 3, 2005.
  1. huntinfool79
    huntinfool79 Registered Member
    Jan 10, 2003
    12
    Helendale, CA
    I am about to put a 6 inch tough country susp lift on my 72' Jimmy need to know will I have to change anything to acomidate the new angle for the rear drive shaft. What are the benefits of moving my tie rod up above the differential as opposed to it being in the front. and if I go with a 1" body lift will I have to Make any mod's to the steering shaft such as lengthening it.
  2. durantk5
    durantk5 Registered Member
    Mar 1, 2005
    50
    Greensboro, NC
    nope, no mods to steering with just one inch of body. i did the same 6 inch tuff country on my 88 and it is driveable. both shafts need to be lengthened a little but they both work. i have a little bit of vibration coming from the rear. i did the 4 inch shackle flip out back which helped with pinion angle so you might look into that.
  3. huntinfool79
    Jan 10, 2003
    12
    Helendale, CA
    did you do the 4 inch shacle flip on top of the 6"lift or go with a 4" flip and a 2" tuff country lift,
