Swamper Question.. what psi do you run?
Discussion in 'The Garage' started by TXsizeK5, Mar 4, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I heard that if you run much over 18 or so psi you "will make short work of balding them in a hurry?"
    Is this true?
    Interco website says 30psi max psi... whats the deal?
    If I had 36x.12.50 SX what psi should i run for daily driving on a 16.5x9.75 rim? Also, how good do these wear and perform on the street? this is gunna be 80% on the road and 20% in mud and sand but i really like the agressive look.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Re: Swamper Question
    i run 39.5x15x16.5 at 16.5PSI in the front and 17PSI in the rear and they are wearing pretty well.
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    30 psi is for the maximum weight rating of the tire....I don't know which specific tire you're looking at, but I recall on my Swampers they are rated at a maximum load of 2500 Lbs/tire @ ~30 psi.
    My truck is around 5000 Lbs, so each tire ONLY sees about 1250 Lbs.....therefore the required air pressure is about half of the maximum value (around 15 psi in my case)
    If you actually ran the tires at 30 psi, it would probably ride stiff as hell, and the center tread would wear down to nothing, while the outer lugs would still be intact. The only positive thing is that they should have a lot less rolling resistance, so your highway mileage would be a lot better, and they may also run quieter with less tread touching the road.
  4. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I see, but if i ran 15 psi on wouldnt the tire come off the bead, as 16.5 rims are infamous for?
  5. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    What PSI does everyone else run?
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I don't know about that.....I assumed you were talking about "street" pressures anyway. Before I added beadlocks, I ran down to around 12 psi offroad. That's about as far as I dared.....I've got 16.5" wheels too! /forums/images/graemlins/grin.gif
    Of course, now I can run at 0 psi if I really wanted to..... /forums/images/graemlins/cool.gif
  7. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I usually go to large parking lot and do the chalk thing.Make a mark all the way across the tires and then drive straight across the lot.If the center is wiped off most,lower the pressure,If the outer edge is wiped off raise the pressure.this lets you see where the tread runs flat.Now I run about22-24 in the front and 16-18 in rear.For a long road trip i raise it about 5 lbs in both to help them roll easier and run a little cooler.38in Swamper TSLs. /forums/images/graemlins/thumb.gif
  8. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I run 38.5x14.50/15 SXs on my burb, and I run 18-19 in the rear, and 21-22 in the front. Good even wear all the way across, but wonders all over the road. For long trips, I put them up to about 25, and it gets alot better gas milage, and doesnt hardly wonder.
    Dan /forums/images/graemlins/burb.gif
  9. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    have someone drive down the street behind you and tell me how much that tire crowns out due to centrifugal force, and the try telling me that all the tread is hitting the ground.
    -Scott
  10. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    16X38X15 TSL bias tires on 14 wide wheels, I run about 20 PSI in them on the street. So far no bad wearing.
