Swamper (SSR) owners!! What PSi to run??>>>
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Burt4x4, Sep 6, 2001.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey fellow Swamper users!!
    I have 35x12.50-15 SSRs and I am currently running about 28psi for my street pressure. The guy at BigO suggested 25 for the best wear and even wear.
    I would like to hear what you all are running on the street.
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I think the best way to tell what psi on your truck is to draw a line with chalk across the tire and drive as straight possible for a ways and then check to see where to chalk has worn off and adjust it from there.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    My friend runs thouse and he runs about 25psi.
    Mike
    <font color=green>"My K5 is purdyr than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  4. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I ran the mud boggs at 10 psi work great never poped a bead. I have not poped a bead yeat.
    colin
    Save the whales Harpoon a fat chick.
  5. Burt4x4
    6,854
    Dude Street pressure!!
    I have hear of that chalk trick. Currently the psi I have been running was able to wear off thoes little tits that are all over a new tire evenly. I mean is that all the little tits from side to side are worn of so the whole trad is hitting the ground.
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    dude this is a Pg site. Cant be talking about tits in here. [​IMG]
    tRustyk5 for President!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  7. Burt4x4
    6,854
    hahaha OOPS!
    LOL...
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I thinks you will be happer with a little more pressure, try 30psi, and also 32psi.
    Good luck
  9. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    i run 28 and it still maybe to high, i wouldn't run any higher. I did and now my middle is worn alot more than the outer. I also have the 14.5 width.
    Doug Krebs
