Swap 14 bolt dana 60
Discussion in 'OffRoad Design' started by braunm, Sep 22, 2001.
  1. braunm
    braunm Registered Member
    May 26, 2001
    77
    Stephen I just got three trucks from the navy. All three are 1 ton chevys.Two trucks have the 205 I think because of the round plate on them. What needs to be done to put them in my 84 blazer? Thanks
    Mike
  2. braunm
    May 26, 2001
    77
    Will 1 ton gear hold up to 37"-38" OK?
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    1 tom gear will hold up to 44s. As for bolting up you need to relocate the spring perches and shock mounts on the rear axle. As for the front axle bolt it in and buy the crossover steering kit. If you dont then just use the steering arm off the truck. I would highly recomend the cossover though. Then all you need is the rear u joint Napa part # 447 I believe.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    These are very simple questions anybody else can reply to you about.
    Post these questions on the main forum and you will get faster and more answers.
    BTW, please fill out your profile. It helps us to help you.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The other replies pretty much lined it all out. The only thing really different between the 1-ton gear and your running gear is the spring perch spacing on the rear, otherwise it'll all bolt up.
    One good thing is you have good choices for which parts to use, and some leftovers to sell to finance the project!
    Making the world better, one truck at a time.
    SW-ORD
    &lt;a target="_blank" href=http://www.offroaddesign.com&gt;www.offroaddesign.com&lt;/a&gt;
  6. coloradoblazers
    coloradoblazers 1/2 ton status Premium Member
    Mar 2, 2001
    506
    WY
    Since you got three trucks, and are using one set of axels, what happens to the rest? I would be interested in a 14 ff and D60 if you are selling!
    K5- because size DOES matter!
    Fear This
  7. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    Me too. I only need a Dana 60. Are you willing to part with them? What gears are they loaded with?
    Diesel
    Shouldn't it be called uncommon sense?
  8. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    If you wanna sell some stuff let us know :) I'm looking for a few things myself.
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  9. braunm
    May 26, 2001
    77
    As far as I know there is 4.56 gear's with no spin's. I am going to find out what a no spin is then I will let you guy's know. I might sell them as of right now I don't know. Thank's for your help.
    Mike
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    "No-Spin" is Trac Tech's official name for the Detroit Locker that mounts into an existing carrier. (I.e. you don't have to buy the entire carrier). This is why a new one for a 14-bolt Full Floater only costs around $300. It just consists of the guts from a Detroit Locker.
  11. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    actually that is the name for the "detroit" locker whether it is a drop in or not
    <a target="_blank" href=http://wsphotofews.excite.com/032/Mp/Wb/58/5H33574.jpg>http://wsphotofews.excite.com/032/Mp/Wb/58/5H33574.jpg</a>
    webshots distorts the image, but it shows "no spin with internal and external springs and with or without support case
  12. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Also with these trucks if you look at the rear axle mounts on the springs they are alot different then a normal set up so you will need the spring plates and u bolts for a 3/4 ton 14ff rear axle. Also there should be a lever assembly where the rear brake line drops down and connects to the lines on the axle. That bracket can be cut so all that is left is the piece to hold the block the lines connect too. Yes you might have 205 t cases also. Most have the th400/208 combo but there were a few with the 205 instead of the 208.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
