Swap 305 to 350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84Blazr, Jan 4, 2001.
  1. 84Blazr
    84Blazr Registered Member
    Nov 29, 2000
    50
    Stillwater, New Jersey
    What would be some possible problems that I will run into by swapping an '86 350 thats currently mated to a SM465 into an '84 K5 that has a 305/700r4? I'm keeping the 700r4. would there be any problems as far as parts not matching up, 'cause I thought that I had heard somewhere that swapping motors newer than 85 into 84 and older would not be just a basic switch, is that true? I would really like to get that 305 outta there soon!! thanks
    Know any GOOD Wheelin' in Northwest Jersey, let me know?
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    You will need a flexplatel from an '86 or newer motor, as they are different from the older style ('86 and newer blocks use one piece rear main seals). The flexplates are not too expensive. Other than that, I can't think of any real problems. I have an '87 motor in my '83, using the original '83 700R4. The donor truck had a manual.
    Pete
    '83 K5, 350 TBI (ex 6.2), Dana 60/14 bolt, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. 84Blazr
    Nov 29, 2000
    50
    Thanks for the info...
