Swap a t350 for a 700r4
Discussion in 'The Garage' started by rpm35, May 31, 2005.
  1. rpm35
    rpm35 Registered Member
    Jan 14, 2003
    71
    Billings, MT
    Last time I went wheeling I managed to break the case on my built 700r4. :mad: I have a t350 I could swap in until I can get the 700 fixed. Will the 350 work with the 241 tc? What changes will need to be made (drivelines, crossmembers, etc.)? Any help will be greatly appreciated. I need to get back on the trail.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if you have a four wheel drive 350 you will need a different drive shaft also the 350 is about 2 inches shorter than the 700
  3. rpm35
    Jan 14, 2003
    71
    Billings, MT
    Thanks for the reply.
    Just one more question, will it matter if the t350 had a 203 behind it?
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes you will need a different output shaft because the output shaft on the 350 is very short stick out
