swap question
Discussion in 'The Garage' started by dheavychevy38, Jan 21, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    How hard and what does it take to swap the pedals of a automatic out and a manuel set in it's place?
    the swap concerns getting rid of a 700r4/208 combo for a 465/205 set? /forums/images/graemlins/truck.gif
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    If you get pedals from similar truck its should me easy swap.The hardest part is Z bar for clutch and bracket on frame.Look how it is on similar truck or go with hydro. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Look up in your dash... you should see a place to hang the pedal there already. I would find the pedal, brackets, springs, etc from a yard truck, and then install a NEW master cylinder into the firewall. The spot should already be in the firewall... you should just have to knock out the hole for it. /forums/images/graemlins/wink.gif
    IIRC...
    -Dan
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Its actually not that hard at all. Can be hard to get a fat hand up in there though. /forums/images/graemlins/tongue.gif
  5. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    It's not a difficult swap at all. Just get everything clutch, pedal, and linkage related from a similar bodystyle year, and it all bolts in.
    Chevy's are so simple!
