Swap TBI to Carb setup--need distributor?
Discussion in 'The Garage' started by 87superblaze, Oct 17, 2003.
  1. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    I would like to swap my TBI for a Carb setup for various reasons. My main concern is if I can still use the distributor from my TBI. I think I'll need to keep the knock sensor.
    I'll also need a mechanical fuel pump(suspect electric in tank is bad), sending unit from a carb blazer, intake to fit 87+ heads and carb, Torque converter lockup wiring kit.
    Is there anything else you can think of I'll need to do this? Will the distributor still work? ANY help is appreciated. Thank You
    BTW: 87 K5 350 automatic, 31 gallon fuel tank
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You'll want to make sure that if your electric fuel pump is bad that it doesn't hinder the flow of gas to the mech. pump.
  3. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    you need a new distributor (HEI), you can go ahead and disconnect he knock sensor cause w/o the ecm it won't work. that's all i can help with sorry.
  4. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    what a sin /forums/images/graemlins/rolleyes.gif
  5. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Ill buy the tank sender /forums/images/graemlins/thumb.gif
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    My friend did this to the 89 p/u I have.... You have to get an HEI or point disty. You EFI Disty wont work... You can run your EFI sending unit.. All my friend did was remove the fuel pump....
  7. 87superblaze
    Mar 12, 2001
    104
    Upper Michigan
    sorry it took so long to reply. The sender is BAD and at $400+ /forums/images/graemlins/mad.gif it is hard to spend that kind of money on something that doesn't help performance.
