swap to 89-91 grille
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 3car, Jan 1, 2002.
  1. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    does the swap to the 89-91 grille require a different radiator support???thanks for the replys...
    eatin'fords and shittin'dodges down in the sunshine state.
  2. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    current support is an 85'thanks
  3. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Yes.. it requires a new radiator support to accept the 4 headlight system.. I have a 83 and a 89 Blazer.. and they are both different near the light mounting area.
    They are priced pretty good in LMC catalog..
    Hope this helps.
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  4. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    thanks rocco.
  5. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Yes, You will need the 89-91 radiator support for four headlight system. I did a technical writeup with part numbers in the Technical section. You should find it helpful. Email me if you ever have questions npickett@toast.net
    Mudzer 1978/91 K5
    <font color=blue><a target="_blank" href=http://www.mudzer.rockcrawler.com>www.mudzer.rockcrawler.com</a></font color=blue>
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Look here for more info.
    <a target="_blank" href=http://www.coloradok5.com/grilleswap.shtml>http://www.coloradok5.com/grilleswap.shtml</a>
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  8. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    thanks for the insight.
  9. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    It's up to $50, now, but still cheap!
    1 ton '87 Chevy SWB in the making!
