Swap
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by dpearson, May 9, 2002.
  1. dpearson
    dpearson Registered Member
    Apr 10, 2000
    95
    El Paso, TX
    I have a 75 Jimmy with 454, th350/205, dana60 and a 14 bolt rear. I was wondering if I could swap the Gen II drive train into a Gen I?
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You would have to move the rear spring mounts and use gen 1 springs on the front. Or you could move the front spring mounts and use the longer springs The rear mount are wider on a gen 2.
  3. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    I couldn't have fit my big block into my truck without the 3" body lift...even after that, the valve covers were awfully close to the firewall.
    For the drivetrain, as long as modifying the spring perches is not a problem, the swap is easy.
    You can use small block motor mounts for the big block, but that can sometimes create oil pan clearance problems with the front crossmember.
