Swap'en Motor Mounts *UpDated*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DuneRunner, Sep 23, 2002.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Swap\'en Motor Mounts *UpDated*
    *Announcers Voice*
    The Cure All Vibrations....(almost)
    Well those what read this post yesterday got a feel for my problems. I was having a hard time getting my old motor mounts out. Well with the help from my dad (DuneRunnersDad) and a 5lbs. sledge and a 100 watt lamp. We finished it in about 2.5 hours.
    I took it for a Cruz last night after all the work and no Vibs what so ever... Except for the fact that the tires might be off balance. The old mounts where both Thrashed. (Nubs cracked almost all the way through) It is one of the best Fix's I've done yet.
    I think that I have replaced almost all of the Factory rubber on the DuneRunner. SO Hopefully it will last another 20 years. Yyaaaa....
    Thank you all that helped out... /forums/images/icons/grin.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Re: Swap\'en Motor Mounts on my 83...HELP
    i would hook it to a lift and do it that way.
    having both undone, they should come out fairly easily. did u get both bols out of each motor mount?
  3. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    No not yet...I han't touched the other side...That will be the next thing I will do. Thanks Zakk /forums/images/icons/laugh.gif
  4. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    I just did mine recently with no problems...
    I removed the bolts from both sides simultaneously and used a floor jack under the pan with a 2X4. Much easier than doing one side at a time...
  5. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I'm off in an Hour. And then another 45mins to get home. Cant waite. MUST LEAVE NOW! Thanks for the idea. Did you use factory rubber or Poly Urathane (sp)?
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i just used factory sheit with mine. new ones will last a while. I am not making enuff power to justify the cost. I got headers for what the motor mounts would have costed.
    if you have a BBC of Caddy 500 motor, that would be the way to go.
  7. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Same goes for me as well...factory rubbers...stock GM parts are usually good enough for my uses.
  8. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Good deal. Glad to hear. I got the Energy Sus. For $48.00 at Vic Hubbord (sp) And they had them in stock... I looked at it like this. (Tank of gas vs. Poly Mounts)
  9. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    ttt. Re-read the original post... /forums/images/icons/grin.gif
