Swaping axles, ration question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grtwhite, Sep 19, 2003.
  1. grtwhite
    grtwhite 1/2 ton status
    Aug 3, 2000
    366
    Macungie, PA
    /forums/images/graemlins/confused.gif I'm swaping out a 14blt ff with 4.10 gears, in favor a 14blt ff out of a 1 ton van. The van axle has 4.09 gears. I beleive it would be with in the margin or error and be fine, just wanted to make sure. Please let me know if other wise. Thanks! /forums/images/graemlins/thumb.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    yep, it'll work....4.09, 4.10 and 4.11 are all safe together /forums/images/graemlins/thumb.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    They should be the same ratio, I would bet that if you count the teeth on both axles they will be exactly the same. Somewhere along the line someone just rounded differently. Rule of thumb is within .02 is fine, so 4.09 with 4.11 would work no problem.
  4. grtwhite
    Aug 3, 2000
    366
    Macungie, PA
    Thanks for the quick replys guys! /forums/images/graemlins/rotfl.gif I counted both axles the pickup was 41 & 10 and the van was 45 & 11.
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    How wierd, I wonder why they would do that...
  6. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Are you sure its not a Dana 60 or 70 that you are taking out of the van?
  7. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    GM did have a 4.09, because my '75 3/4t, had a 4.09 ratio in it. Don't 1t GM vans use the 14 bolt???
  8. grtwhite
    Aug 3, 2000
    366
    Macungie, PA
    Its a 14 blt. It came out of a 77' 1 ton ambulance. /forums/images/graemlins/pimp1.gif
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    gm had soem funky ratios, dont forget the late 60s and early 70s dana 44 3/4 ton 4.55 ratio
    then 3.40 in someof the 10 and 12 bolt rears.
    theres a few more odd ones
    4.09 to 4.11 would be fine, no worries, although try and avoid 4loc on dry pavement if at all possible
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Try to avoid 4 loc on dry pavement anyway.
    The rule of thumb is within 3% I do believe. Every tire comes out of the mold differently anyway so they also affect this.
