Swaping the 60 and 14b for 3/4 ton rears
Discussion in 'The Garage' started by 84CUCV, Dec 19, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    On my M1028 i am taking the 60 and 14 out and want to put 10b and a 14sf in. Can i use the u bolts and the rest of the hardware? i know i need 10b spring plates, anything else i should know before i do this??
    thanks mike
  2. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    you already said spring plates... I think you will be ok with the u-bolts for the rear, but you will need all new hardware for the front?
    What are you putting the 1-ton goodies under?
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    They are going into my 84 M1009. I am goign to use the m1028 as a DD for a while. Thanks mike
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Anyone, know what else i will need?? any tips? thanks mike
  5. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    info requested
    dont forget the front plates on top of the springs. might need a smaller master cylinder for brakes possibly. i would get new ubolts for the front and rear NEVER had good luck reusing them all most lost front axle once. 5 week old uolts lossened up to put shims in then re tourqed and whent on poker run front all most fell out VARY BAD ride.
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks
  7. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I can see no reason to change the master cylinder. What... to have less brakes if anything?
