Swaping transfer casses
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by codyoffroad, Nov 3, 2002.
  1. codyoffroad
    codyoffroad Registered Member
    Aug 14, 2002
    6
    Montana
    I was woundering if ang body has a full-time 4x4 and has swaped out the np 203 and put in a 208 or 205? Would the transfercase bolt right up to my current th350 or would I need a adapter/different th350. /forums/images/graemlins/truck.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I was kinda wondering the same thing as I have a TH350-NP203 and would like to do the TH350-NP205/NP203 doubler.
    Bill
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    As long as you get the correct adapter with the transfer case they will bolt right together. So you would need an NP205 with a TH350 adapter or a 208 with 350 adapter. The np203 adapter will ONLY work with a 203. That is also true for the other transfer cases.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Keep in mind that most such swaps will also require that the driveshafts be modified. That can add a few hundred bucks to the cost of the swap. /forums/images/graemlins/frown.gif The 203 is a pretty stout case. A 208 would get you a lower ratio in low range, but it's also weaker than a 203. A 205 is slightly stronger, but has nearly the same low range ratio as the 203. So unless your 203 is trashed, there isn't much reason to swap it out. It might need to be treated to a new chain after 20 to 30 years of abuse, but other than that I wouldn't worry about it.
  5. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Also be sure that the t-case has the right input shaft and coupler.
