Swapp 14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blazer350, Oct 13, 2001.
  1. 85blazer350
    85blazer350 Registered Member
    Sep 5, 2001
    51
    Grande Prairie,Alberta,Canada
    I was just wondering if a 3/4 front and rear axles will go directly into my 85 blazer without any prblems and if I would have to move the spring perches or shock mounts.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes they will bolt right into place of the stock Blazer axles, no problems.
    The only thing to look at are the e-brake cables and the u-joint for the rear drive shaft at the pinion end.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Yep, theyre a direct swap. Like Wes said, youll need the rear u-joint(NAPA #447) and dont forget about the 3/4 ton axles will be 8 lug.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  4. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    and if you have a lift over 4 inches you might want to cut and weld the spring perches to give that driveline a better angle.
    Surfing is Life...
  5. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    like said above,it is a direct bolt in.I had a new driveshaft made with the proper u-joint instead of using the conversion joint.But this can be done in the future if you want.
    chevrules...always has and always will
