swapped in np205... now no speedo...
Discussion in 'The Garage' started by jekbrown, Apr 2, 2003.
  1. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    i shoulda asked the guys at the shop about this but i forgot. They swapped a 208 out from behind my 700r4 and put a np205 in... now my speedo doesnt work at all (ie, sits at -5 mph the entire time i drive /forums/images/graemlins/wink.gif ). Is getting the thing working again purdy simple or...? What do I need to do?
    j
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Did they hook up the speedo cable?
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Do you have a cable driven speedo or a electrical one?
  4. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    pretty sure my original speedo was cable driven. Are speedo cables generally capatible... ie, i can just use the same one I had or...?
    j
  5. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    It might be somthing simple like they did not get the inner drive cable engauged in the speedo gear when they installed it. When I move min around I take the end off the transfer case and push it in while spinning it so it drops into the speed. Then line up the little cable end with the transfer cases speed gear drive before twisting it back on.
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Assuming your truck is pre 90', just simply take your speedo cable and hook it up to the speedo and Bam, you now have a working speedometer... /forums/images/graemlins/smile.gif
    Boss
  7. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    Im not lookin at it right now, so i need help with visualizaton... is the place that the speedo cable attaches too on the a$$ end of the tranny or on the tcase itself? btw, my rig is a '85, so definitely pre 90. /forums/images/graemlins/grin.gif
    j
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The speedo cable goes into the t-case on 4x4's, it goes into the tranny on 2x4's...
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    The speedo cable screws into the tail housing of the t-case it is a few inches forward of the rear yoke on the tail housing
    Chris
  10. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    sweet, thanks for the help guys! /forums/images/graemlins/grin.gif
    j
  11. fredekr
    fredekr Registered Member
    Jul 12, 2002
    92
    Colorado Springs, CO
    Also, both xfer cases I've had -- a 203 and a 205 -- failed to actually turn my (new) speedo cable. As Chris observed, the stamped design of the square socket on the transfer case wears out over time -- I took a 1/4" x ~1.5" strip of very thin aluminum (aka beer can /forums/images/graemlins/thumb.gif) and shimmed out the round hole so that it is tight on the square plug.
    cheers!
    Kevin
  12. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    good advice!! I'll have to see what I can come up with.. i dunno.. i didnt talk to the guys who swapped the cases, maybe they just forgot to hook the cable up. <shrug> this weekend I'll check it out when I visit my rig.... no doubt more questions will follow then. /forums/images/graemlins/grin.gif
    j
  13. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I had the same problem when i went to a 205 from my old 203. I hooked the cable back in, but it never worked after that. I considered it a good thing, cause it also runs your odometer. My odometer makes the most annooying noise you can imagine, it gets stuck on .9 when it trys to roll over the next mile and ticks and grinds on itself. And it wasnt accurate anyway, so i take it as one less bad noise to explain to the gf's. /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  14. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    One more thing you might want to check is the actual speedo gear inside the tailhousing. My old 205 had a plastic one on it and the teeth had worn off.
