Swapped in the Big Block this weekend....~PICS~
Discussion in 'The Garage' started by Zeus33rd, Oct 14, 2002.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Check out the pictures.... Here. The first 5 pics in the gallery.
    I'll have some pics of the finished install tommorrow. To dark for pictures when I finished. /forums/images/graemlins/pimp1.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    congrats /forums/images/graemlins/thumb.gif
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Congratulations! you'll love the power. Where's the flywheell?
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Cool. You'll never go back to a small-block....
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Did it bolt right up to the stock engine mounts? Anything special have to be done?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
  7. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Hey, looks great! I've got a 402 BBC in my other '80 K10 that some previous owner swapped in. I removed it this summer, and I'm thinking about rebuilding it and putting the 402 in my daily driver (another '80 K10 titled as '74) to replace the no compression, oil leaking/burning environmental hazard, no power 305 currently in there. My 305 is so worn out, even changing the gears from 3.42 to 4.10 was not real noticeable, except on the highway!
  8. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    cool /forums/images/graemlins/thumb.gif
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Blazer79- At the time of the picture the flexplate was sittin on the work table in the shop. /forums/images/graemlins/rotfl.gif lol, I noticed it about 5 minutes after I took the pics......Engine was about halfway lowered into the truck. So no big deal. /forums/images/graemlins/smile.gif
    85Mouse- Everything bolted up just like a glove. Used the same motor mounts from the small block. The only "custom" work I had to do, was figure out a way to mount the 4 core radiator and shroud from the '82 donor truck. Just had to drill four holes and that was it. Everything else went smoothly. /forums/images/graemlins/thumb.gif
  10. Blazer79
    1,816
    /forums/images/graemlins/rotfl.gif Exact same thing happened to me, that's why I asked. I started to lower my 454 (with the help of my g/f!!) when I realized there was no flexplate /forums/images/graemlins/blush.gif
    Worst part is I couldn't find all the bolts at the moment, so I "borrowed" a few from my ex-350, which is now my brother's property.
    She was like /forums/images/graemlins/rolleyes.gif
  11. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I've got two real issues to work out before it runs perfect. Went to set timing today, and found I have the distriutor off one tooth. Gonna fix that tommorrow. Also, the q-jet from my old SB does not run right on the BB. Totally craps out about 3500 RPM's, Sometimes it'll hit 4500-5000, but it falls flat on it's face eventually. Anyone got any suggestions about what carb would work well on this motor? I assume I should try to find one from a BB? /forums/images/graemlins/confused.gif /forums/images/graemlins/deal.gif
  12. Blazer79
    1,816
    I'm running an Edelbrock Q-jet #1902. Rated 750cfm runs great.
    You mean you've revved the big block past 4000rpm? /forums/images/graemlins/shocked.gif I've never done that.
  13. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    This motor seems to like to rev past 4000...Full roller aluminum rockers, forged pistons, balanced crank. It's a '71 402 BB. Out of a K20 I believe. I've got dual Flowmaster 40 series delta flows- It sounds BAD ASS. Music to my ears. /forums/images/graemlins/ears.gif
    As far as the carb.....That 1902 is definatley the one I want....I just don't have the almost $400 for one. That'd be my "dream" carb. Either the 1902 or the Jet Stage 2 Q-jet. /forums/images/graemlins/pimp1.gif
