swapped out t350 for 700r4
Discussion in 'The Garage' started by Bobby Jennings, Jan 12, 2007.
  1. Bobby Jennings
    Bobby Jennings Registered Member
    May 8, 2006
    7
    california
    hey all,
    quick question. changed out stock trbo350 for 700r4 trany with overdrive. do i have to swap steering column for overdrive column. or can i safely tinker with original to work? any help or ideas would be awsome here.
  2. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    you could probably just put it in "d" on the origional and be in "OD"? check bowtieoverdrives.com
    it helped me tremendously
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    I did that same swap in my 77, and kept the original column. I just adjusted it so when I put it into D, it was in OD, when I put it into 2, it was in D, and 1 was 2. Wasn't possible to get it down into 1, but I don't think that really matters much, unless you really like downshifting your automatics!
  4. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    I did a similar swap on my 1974 and the stock column works fine, the indicators are disconnected, but i know what gear my truck is in at all times. With my column, you need to make sure its all the way in park. I still get full control of first gear which i prefer for wheeling. It barely works, if i were to do it again, id try to find a 700r4 column because they have a longer throw from park to first gear so there is no need to slam park or first gear for it to work properly, but i like the lights and wipers located on the dash.
  5. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    pull cluster and remove the indacator plate its 2 screws. and add the overdrive indacator plate in to it.
  6. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I was thinking the same as SweetK30 but I didn't hear about a longer throw:confused:
    Several people have swapped to an OD tranny and not changed anything on the column.
  7. sweetk30
    Nov 1, 2004
    25,546
    542
    simplafyed mine reread it.
  8. Bobby Jennings
    May 8, 2006
    7
    california
    thanks fer tip on 700r4
    thanks sweetk30, that sounds a good change over. im trying to keep the truck user friendly, so my lady can drive it without a custome made handboo0k of bobbyisms. lol.
  9. Bobby Jennings
    May 8, 2006
    7
    california
    thanks for the web address, i'll try it.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The columns are the same for TH400, TH350, 700R4. The only thing that changed between the TH400/TH350 to the 700R4 was the indicator bolted to the cluster as was already stated.
  11. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Thats what I did and it work's fine. :D
