Swappin axles
Discussion in 'The Garage' started by Mreetz, May 25, 2002.
  1. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Why are these brake lines such B*tch to get off? They don't screw in counter-clockwise do they?
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I busted my rear line up at the body trying to get that one off, with the correct tools none the less. Even worse, the brake flaring tool doesn't work on my lines for some unknown reason, @#$@#% brakes! At least the front went in well durring the swap!
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    wont flare right huh ? try vise grips on the part that holds the tubing . /forums/images/icons/smile.gif
  4. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Hey, sounds like you've tried that before... ok, I will!
  5. Mreetz
    Jun 26, 2001
    1,282
    I'm doin that on the old tearin it apart but it still ain't comin loose!!!
  6. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    HAHA YEAH , but not on my truck ! it was a customers f150 prerunner ! doh ! yeah i got it to work tho , it wasnt holding it tight enuff .
  7. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Mine was so bad, I had to cut the line and buy a new fitting! Hence the flaring problem, smae thing happened on the front right but I replaced the whole tube from the proportioning valve to the right wheel frame mount.
  8. Mreetz
    Jun 26, 2001
    1,282
    I think I'm headin in the direction of cuttin and replacin too, oh well I was wonderin what I was goin to do with the extra day this weekend.......
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    can you put antisieze compound on the fittings so that they will be removeable next time?
