swappin in a d44 and 12bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Dec 19, 2000.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    I thinking about swapping in a d44 and 12bolt from a '71 into my '84. Is this difficult swap or is it pretty much a straight forward bolt-in swap.
  2. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I don't think the spring perches line up from the first gen. blazers..there might be track width issues too. I would do the swap using 74-80 axles..my bud runs 39's with this combo and ain't broke yet! Should bolt right up, but keep in mind that 3/4 ton bolts right up , too. Just buy some 8 lug 15 inch rims from Summit and grind down your 1/2 ton calipers a bit-good luck
    "I'm not stuck...I just dropped my beer in my lap"
  3. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    The front D44 would drop right in, The rear 12B is another story. The spring perches and the shock mounts will have to be moved to mount on your 84.
    [​IMG] I have to agree with the Puddy Cat. [​IMG]
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    You might also want to verify the Dana 44 is one of the early versions with the little u-joints (Spicer 260-x joints versus the larger 297-x size joint).
