swapping 10 to 12: Ujoint ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Apr 19, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    swapping to 12 bolt from 10 bolt, both half ton of course, U joints same size or no ? possible joint width difference ? both are 1310 right ? or ?
    thanks for anything
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i've been told they are a different size, but was also told that you could change the pinion yokes out between the two. just need a different size seal. i just happen to have the part # it's cr19277.
  3. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    All you need is a special U-joint. NAPA sells them. The number on mine says 348. One side of the cross is setup for the 10 bolt shaft and the other is setup for the 12bolt yoke.
    Just remember to get two, and carry the second as a spare.
    Kent
  4. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    The 10 bolt is a 1330 joint...it is bigger !!
    the conversion joint is brute force 3-3130 from autozone.
    That seal to convert the yokes is wrong..that part nubmer is just a standard 10 bolt yoke seal and will not fit into the 12 bolt housing. Trust me...I've tried it.
    Blake
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    good to know!
    so is the difference in width or cap diameter of the joints ?
    i may have lucked out in that i may have a 2wd 12 bolt th350 shaft from a late 70s truck around, oh wait, DUH FOR ME, i could just take shaft fromt he 79...... ok problem solved.. my bad
    thats crazy..
    thanks!
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Kent
    The 348 is to go from 12b to 14b ff.
