swapping 14 bolt sf to an 88' 1/2 ton truck
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MilpitasK5, Apr 28, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    swapping 14 bolt sf to an 88\' 1/2 ton truck
    Will this bolt right in? Or will it need a different U Joint or something?
    Its a 14b SF from an 88' 3/4 ton "light duty" silverado.
    Or just post a key word that I can use for a search if you know there are plenty of posts out there.
    /forums/images/graemlins/crazy.gif
    Thanks in advance!
  2. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Re: swapping 14 bolt sf to an 88\' 1/2 ton truck
    Try this in search: "14 bolt sf swap" /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    thanks...
  4. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    looks like it will bolt right in. There weren't any posts for swapping to trucks, just blazers.
    If anyone knows off hand if the ujoints are the same, let me know.
    Thanks,
  5. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    If you currently have a 10 bolt, you will need a napa, or precision, #447 U-joint. It is half 1310 and half 1350.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    swapping trucks and blazers is the same.
  7. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    just to clarify a lil .. you are swapping a 14SF from an '88 LD 3/4T into an '88 pickup? Also guessing both 88 trucks are 4x4's. If so, it ought to be an easy swap. Should just need the different u-joint (447 IIRC). If its an 88 axle going into an 87 or older truck or 91 or older blazer/burb you will need the new joint and to redo the shock and spring mounts. There will likely need to be something done with the e-brake but I am not sure what exactly. When I did mine I swapped to disc and have not done anything about the e-brake yet.
  8. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Thanks everyone! /forums/images/graemlins/thumb.gif They are both 88' /forums/images/graemlins/truck.gif and they are both 4x4s.
    It's a friend of mine's project.
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    u bolts too.
