Swapping 5 spd manuel into 82 Jimmy
Discussion in 'The Garage' started by hidesertwheelin, Jan 21, 2007.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Has anyone ever swapped in a 5 spd manul tranny out of saya 88-94 chevy truck? I know the bellhousing should bolt right up, but are there any fitmant problems with the linkage,etc? I know it doesn't have the granny gear, nvg4500 yada yada yada. I don't want to spedn that munch money an it's going in my daily driver.
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Can't rememeber which year, but sometime in the 90's they switched from external to internal slave cylinder. Avoid that like the plague, the hydraulic throwout bearing versions that is, I'm on my 4th one in my '97, I've tried OEM and aftermarket ones. They only seem to last 30-50k miles. Nothing like haveing to pull the trans just to change the slave cylinder.
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    Does anyone know how many splines the NV3500 has on it's output shaft? Can a guy bolt an NP241 up to it?
    I wouldn't mind one of those 5 speeds in my K5 either...
  4. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    32 spline and the 241 came stock behind them.
    Rene
  5. Russell
    Jun 23, 2000
    7,927
    343
    I thought the NV4500s were the 32 spline setups, NV3500 is too?
    That'd be sweet, cause I've got a pass side drop NP241 with a cable drive I could use...
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    All the manual tranny's after '80 were 32 spline. Probably still are.
    Rene
  7. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    If you decide to do this swap I would be interested in doing my truck as well. I live down the hill from you maybe we could link brains and figure it out together?
    ~Brian
    p.s. I still have your fence. My wife didn't know I was expecting someone and I didn't want the water outside to ruin the wood.
  8. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    I'm with tRusty on the spline count. I have a NV 3500 in my 2 door tahoe that is being replaced with an NV 4500. The spline count on both is 32. The s truck versions are smaller though. My Tahoe is an external slave model. Not sure on the 3500's but the 4500 changed to the internal slave in 1996.
  9. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    one big problem boys . the slave is pass side. you might run in to drive shaft to slave housing problems.
  10. Russell
    Jun 23, 2000
    7,927
    343
    As much as people hate em, its easy enough to run an internal slave to get around that problem...
  11. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I'm doing some research on the swap. I'll let you know if I thinks it's doable and cheap :D I'll PM about the fence. Thanks.
  12. Russell
    Jun 23, 2000
    7,927
    343
    I'm with ya!
    My 96 has an NV3500, with a noisy second gear syncro. I'm thinking of dropping that tranny into the wheeler, and getting a freshly rebuilt one to put into the DD with a Vortec 5.7L...
    Lemme know if you find anything interesting on the topic, and I'll do the same...
