Swapping a 14 FF and a Dana 44 in place of 1/2 10 bolts, any advice?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silverado4x4, Feb 17, 2001.
  1. Silverado4x4
    Silverado4x4 Registered Member
    Oct 2, 2000
    61
    Illinios, southwest of chicago
    Just wondering if theres any trouble i'll run into or advice other than whats in the tech article?
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Both Steve (here @ K5 under projects and his UAB) and Shawn (@ www.offroad.com) have big write ups that will tell you everything you need and have some great pics...
    Not sure if knew about Shawn's article. From what I hear just make sure they aren't 1 ton axles for a 1/2 and you'll be ok.
    good luck
    1987 Chevy K5 Blazer- 350 TBI
  3. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    The spring perches on the rear would have to be moved if it is a 1 ton. Better of with the 3/4 ton 14 bolt. Should bolt right up.
    Scott
    78blazer
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Not only the spring perches, but the shock mounts need to be relocated also.
