Swapping a 208 for a 241
Discussion in 'The Garage' started by stallion85, Dec 2, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I have a SM465 and a 208. I want a 241 so I can get the lower gear and the SYE adapter. If I find one behind another 4 speed will it be a direct bolt on?
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    As long as it came from behind a 465 it is a direct swap.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if its behind a 465, th400 or 4L80E its all a swap in. the only difference is the 32 spline input, all these have that.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Also you would want one with a mechanical speedo. They came ONLY in 1989 models. I have a swapped in 241 and like it.
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Super Short kit has speedo setup just only if you have a factory electric speedo.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Do you have a problem with alot of rear flex slipping the yoke out to far? If not I personally don't think it is worth the time and money to swap to a 241. The .11 extra gear reduction is basically worthless in terms of crawl.
    Unless your 208 is broken or you slip out your slipyoke I would keep the 208.
    If you are needing to get the 241 you need on from behind a TH400 or SM465. They will bolt up in place of a 208 without any mods I believe.
    Harley
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    shift arms on a 241 vs a 208 are different. Tork has a fix, just cut the 241 arm and turn it 90 degress and bam it works. Its just some different mounting between the two that makes one not work.
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    241 is a little better since you can do a easy SYE and it has a better oiling system but if have to do alot searching to get one to work with your tranny then it wouldnt be much worth it.
