Swapping a 4wd pitman shaft for a 2wd
Discussion in 'The Garage' started by K5thatShmobs, Mar 26, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Anyone whos done this, how much work is involved? Looking at the image below, am I going to have to mess with any of the parts that are below the pitman shaft (numbers 25,28,27,26,29,30,31,and 32)? Or can I just unbolt the top part (number 46) and slide the shaft up and out? Whats the deal?
  2. 82TOYLB
    82TOYLB Registered Member
    Nov 28, 2001
    61
    Sacramento California
    That depends on how dirty your old sector shaft is when you pull it out (#44), or how old and leaky your seals already are. I chose to replace the seals on the bottom of 44 and on the top plate when I did it. It is not hard at all, Napa sells the partial seal kit just for this for ~$12. Yes, you can just unbolt the top plate and pull the shaft out, just make sure the wheels are straight when you start. A slight tap is all it should take to unseat it. PS fluid will go everywhere. Have Fun.
