swapping a detriot in place of a gov loc.
Discussion in 'The Garage' started by 55Willy, Oct 30, 2005.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm getting a van 14ff for the jeep and want to swap my current detriot into it. I also want to change gear ratios as I do it. whats cheaper money wise.
    swap my current 14ff into the burb with the current detriot and 4.10s and just buy a new detriot and some 488's or 513s for the van width one? or swap everything around just to keep the current detriot in the jeep?
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i thought u wanted to know something about a gov-lock detriot swap.... i am so confused??
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    does the van width 14 bolt have the gov lock? if so you can't put a detroit in it, you need an open carrier. I am confused too :confused:
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you will need a new carrier for the 14ff with the gov-lock to be able to put a detroit in it
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    i wanna put a detriot in the gov loc'd van axel.
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I did that with my Gov Lock axle. I yanked the carrier out of a donor axle and installed the detroit with my Ring gear on the new carrier. I haven't had any probs with 1200 miles on it so far.
  7. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    Can you use any carrier for your gear range ie 4.10 and down (numerically) or does it need to be the same gear ratio? In other words can I use an open carrier that came out of axle with 3.73 gear ratio, for mine with a 4.10 ratio?
    Also, any difference between the newer and older styles? I have the later style 14 BFF with all the vanes on it?
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no it dose not need to be the same ratio
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yes.
    Yes, there is a difference.
  10. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    hey whats up shane.
    so I gotta find one from the newer style? that sucks. do you know if there is a difference in the detroit's also, or is it one size fits all?
    thanks in advance
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    detroit is a one fits all on 14ff
  12. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Hey Morgan. How's it been?
    What Shannon said. The lockers are the same. The difference is in the install kit. Different bearings, etc.
  13. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    been good, busy, not enough time to screw with the truck...
    Cool, so basically I need a 2nd design install kit and carrier.
