swapping a hei dist into a ccc blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by supersize75k5, Aug 21, 2004.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I want to get rid of my computer control carb and dist. I yanked the carb and put on my truck advenger but I need to know if there is anything special I need to do, or can I just drop a dist. in, also what about getting a full 12 volts, just get it from the distribution block on the fire wall?
    any help is greatly needed, thanks guys /forums/images/graemlins/thumb.gif
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    All you do is use the regular HEI and the power in on said distributor is same as other one . I removed my ESC distributor and put in one for a 76 V-8 Nova . Actually I was looking at my old one yesterday , and without removing the disutributor you could just remove the computer plug stuff from old one and swap in regular module and harness ( the parts under rotor ) , and also vacuum can if you needed one . /forums/images/graemlins/k5.gif
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I believe even the early computer controlled distributors did not use mechanical advance weights so you can't just change the module and wiring.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My 83 , which had ESC but no CCC Carb , has the weatherpack connector for the spark computer , and mechanical weights and vacuum can . Dunno if it was because mine was early or not /forums/images/graemlins/dunno.gif
  5. dyeager535
    26,982
    191
    CCC uses no weights (same idea as fuel injected distributors) while the ESC distributors CAN be converted to "normal" HEI distributors.
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I just dropped on an edel Q-jet and an old HEI dist, hooked it all up, and roll /forums/images/graemlins/thumb.gifed.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    theres no real rule of thumb on this,.
    80 was first year for EST,
    EST is what it was called til around 85 then ESC came out
    ESC is a little more involved of a system than EST was,
    both have pretty much all the same components and look to them,
    the HEI 80-up were varied, some had vacuum and weights, some had one or the other only, and others had neither,
    and yes the ones with the extra four wire weatherpack plug yep
    ive seen all combos
    the rule of thumb that says that if its got vacuum on it then its a non ECM controlled HEI is not true completely in some cases, GM was odd like this,
    there are ECM HEI's with vacuum out there ive seen them i just throw them away though
    swapping to non ECM HEI is nothing at all, no mods to be done, just swap and plug back in and ignore the four wire ECM plug, its cake walk,
    id set engine to #1 firing postion TDC first though before removign the ECM HEI
    then all you gotta do is swap on a non ECM carb too and then youre all done pretty much
    non ECM carb be found on 80 and older and also on 80-up 8600 and up GVW trucks
    80-up cars all models had ECM HEI thanks to their lower GVW
    lower GVW always got the most emissions crap
    in 80 i think some of the BIG 10 didnt get the EST system and could be liek that with 6200+ GVW
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  9. dyeager535
    26,982
    191
    There is no such thing as ECM controlled timing only. Either it has the ECM, (which means MAP, TPS, MCS, O2) or it has the spark timing computer. ECM=CCC, EST=module.
    You will NOT find a CCC vehicle (truck or car) that has anything other than ECM controlled spark advance. No weights, no vacuum, solely computer controlled, just like TBI/TPI.
