Swapping a NP208 for a NP241 - will it work?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mattman, Sep 12, 2002.
  1. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    I am about to get a '87 parts truck with a good 350 TBI and a good 700R4. IIRC '87 blazer's had an NP208. Since this is going in my '90 Jimmy, it would be nice to keep my NP241 since I have the electronic speedo (no speedometer cable).
    The question is is this a straight swap? Can I just pull the 350 and 700R4 from the '87 and mate with my NP241 for a nice and easy swap? Did the output shaft spline count change between these years?
    My big problem is the 350 and 700R4 in my '90 is shot and need rebuilding so if I don't have to rebuild the tranny it would be sweet.
    Thanks for any help.
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    talk to rocko...he's done this swap.
  3. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    i am not 100% sure but i think the front output is on the opposite side as the Np208???? "could be wrong though"
    Ck1500
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    YES, the 87 350/700R4 combo will bolt directly up to your NP241 transfer case. Just make sure you use your NP241 adapter plate and crossmember.
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    As far as Bolt patterns and spline counts the 208 and the 241 are identical. After that the simularities go in opposite directions. But to answer your question, Yes. Go for it.
  6. mattman
    Feb 15, 2001
    152
    Austin, Texas
    Thanks guys. I thought it should be simple but I wasn't entirely sure. Just preparing before I get into it.
