Swapping a tbi 454 in place of tbi 350
Discussion in 'The Garage' started by MudFrog, Mar 1, 2005.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I'm looking at purchasing an 87 Suburban, it would be just for the engine. He said it runs rough due to a problem with the fuel injection. Now I know the Throttle Body is different but what can be reused from my blazer's factory setup (89 blazer).
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Almost everything is the same on the wireing harness and will plug in except the IAC solonoid. and the TPS on a 87 is diferent than a 89. But you can easily splice solder and shrink wrap the right connectors on.
    You can use the 350 ECM its is the same as 454. All you need to do is put the 454 chip in it
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I've been interested in doing the same thing for a while. I know I can work out the mounting and everything but I'm worried about the computers. You're saying that if I get a complete TBI 454 basically everything will plug right in and all you need to do is get the chip from the truck with the 454??? That would be awesome.
