Swapping a Th400 in place of my Th350 Whats Needed?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Blazer, Apr 22, 2002.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    Currently I have a 84m1009 with a 400/350/203 in it and I am gonna be swapping a Th400/208 into it. What will I need to change to make this all work? Can I use the converter and fly wheel from my current setup or will I need something different? I am thinking I have to keep the same flywheel either way becuase it is balanced for the 400? Any help would be greatly appreciated.
  2. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    You need to use the 400's flywheel. Get the 208's crossmember and drill new holes in the frame for it. You'll probably need to modify or cut a new hole for the 208's shifter to fit through. I just swapped a TH400 for my TH350 and the factory linkage worked. You'll have to cut the vacuum modulator line shorter. You'll have to modify the front and rear driveshaft. You'll need a kickdown switch for automatic downshifts. I think the converters are the same but you might check on that. Good luck.
  3. 78Blazer
    873
    Michigan
    Well I should have said earlier the truck origionaly came with a 6.2/400/208. But when I got it it was stripped I added the 400/350/203. So the holes are already in the frame everything else should line right up I think. I do have a rear drive shaft for it already but I will need to get the front one for it. As far as the kick down switch goes where does it go??
  4. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    The T400 kickdown switch mounts to the gas pedal bracket, under the dash. The T350 and T400 convertors are not the same- but are interchangeable (as long as it is not the T350C- lockup version). When a T350 conv is used in the T400, it gives a slightly better stall because of the smaller diameter.
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I'm wanting to do the same thing. I have a 350/th350/205 setup. Will the th400 bolt up to my engine?
