Swapping axles...have a couple of ?'s
Discussion in 'The Garage' started by BlazerWheels, Jul 21, 2004.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    Swapping axles...have a couple of ?\'s
    I am swapping a d44/12b in for 10b/10b. Basically to get gears I want. Don't need to go 3/4ton for now. My question is, will I need to do anything to driveshafts or brakes when I do my swap? Current stuff is stock '85 K5... /forums/images/graemlins/ears.gif
    Thanks in advance
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: Swapping axles...have a couple of ?\'s
    Front is a straight swap. for the rear what is the 12 bolt out of? In the 85 your ebrake cables are different then if the 12 is an older model.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You need a conversion u-joint to go from 10 bolt shaft to 12 bolt pinion . Tim posted numbers in the part number post . If it is a 2wd truck 12 bolt , and you have a shackle flip , the drivers side shock mount will be low and you will have to remount or run that shock upside down . If it is a 4wd 12 bolt , just buy the u-joint and everything else is kosher . I left my brakes on the truck , undid backing plates and slid 10 bolt out , put in 12 bolt and backing plates bolted right up , and the lines went right in on the hold downs on the tubes too /forums/images/graemlins/k5.gif
  4. BlazerWheels
    Feb 13, 2003
    587
    California
    What about the raised steering arm...will it swap from the 10b to the d44????
  5. BlazerWheels
    Feb 13, 2003
    587
    California
    [/ QUOTE ]from a 76 4wd 1/2ton
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    same arm.
    on the rear being from the 70's you will need the conversion u joint and to either swap ebrake brackets and cables or just retain the 10 bolt backing plates as stated up above.
