swapping axles i have a question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ilikeitloud, Feb 1, 2004.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    alright my buddy and me just picked up a gm 10bolt 3/4ton front axle and a rear corprate 14bolt full floater... are these axles bolt in on an 88k5?
    thanx
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    If the 14 bolt is out of a 3/4 ton 4x4 it will bolt right in. If its from a 2wd or a 1 ton the shock mounts and spring perches will need to be moved. The 10 bolt will bolt in.
  3. ilikeitloud
    Oct 30, 2003
    134
    am i going to need new u-joints??
  4. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    The front driveshaft will bolt right up. The rear will need a special u-joint that has the small 1310 size for the back of the shaft and a 1350 for the axle yoke. I forget what the part number is.
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the rear conversion joint depends on your transmission i believe..
  6. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    It is USUALLY a NAPA/Precision ujoint #447.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    If its from a 2wd the shock mounts and spring perches will need to be moved.
    [/ QUOTE ]This is not true if the 14BFF 2wd came out of a 3/4ton. A 4wd and 2wd 3/4 14BFF are exactly the same besides the shock mounts being a little longer on the 2wd.
    THe part number for the conversion u-joint is 2-1153 for a neapco joint, which is better quality than the napa joints(IMHO).
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I took my 3/4 ton 14bff out of a '76 P/U and just bolted it right in with of course the conversion u-joint, I did however notice i have alittle too much braking power coming from the rear now, i believe this to be caused by the larger brake pad surfaces (13" drums) and still running the stock 1/2 ton front disks as i haven't gotten around to converting the front yet..
