swapping carriers??
Discussion in 'The Garage' started by smprider112, Sep 19, 2004.
  1. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    OK, so I have a Gov-lock in my wheelin trucks rear end, and I have an Open in my DD/mild trail truck...both are 14bolts w/4.10 gears....now my question is, I'd like to have the gov-loc in my DD truck, since I dont really NEED a locker in it...but my trail truck I do, so I want the open carrier in it so I can get a detroit....now for the question, can I just take the carriers out, remove the ring gears, then swap the carriers?? then put the ring gear back in the truck they came from? and by doing this will I have to re-set up the gears? or should everything line right up??
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    you will prolly have to reset backlash, and run a pattern, but thats not too bad.
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    why not just swap axles axles /forums/images/graemlins/dunno.gif
  4. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Brian, I lost your email addy and cannot pm now, im a bluebie, email me 6Dekkers@comcast.net /forums/images/graemlins/thumb.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I was thinking the same thing.
  6. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    I could do axle to axle swap....but really wanted to avoid all that hassle /forums/images/graemlins/blush.gif /forums/images/graemlins/1zhelp.gif
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    yeah, just reset backlash. If you know how to do that, i think it would be easier to swap the carrier.
  8. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    how do u set the backlash?? /forums/images/graemlins/dunno.gif
  9. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    If it were me,I'd swap the entire axle assembly--its easier to remove and install 4 U-bolts,a few brake lines,and E-brake cables,and the rear U-joint,than to try and set up gears while the housing is still in the truck--and might not last anyway--at least it seems easier to me-- /forums/images/graemlins/thinking.gif
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You can do it 2 ways. Check the backlash on both axles. Then take everyhting from one (pinion, subcarrier, shim, carrier and ring gear) and put it in the other.
    Or
    Check backlash. Pull the gov loc out take the ring gear off. take the ring gear you want, put it on the gov loc, and reset the backlash.
  11. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    hmmm...maybe I'll just wait till Im ready to do 4.88's in my trail truck...then just get an open carrier from somewhere else...since the gears will have to be setup then either way /forums/images/graemlins/thumb.gif
  12. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The used gears you take out wont have to be "set up". They already are. Just check the backlash, and reset it to that when you put it back together.
