Swapping D60 inner shaft question?
Discussion in 'The Garage' started by eldon519, Jun 18, 2003.
  1. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    Just recently I decided to swap my Dana 60 stub shafts for the 1.5" 35 spline shafts and upon removing the inner shafts, discovered they are the less desirable tapered shafts. I got a decent deal on some non-tapered inner shafts, so I'm gonna go ahead and install them. One question though, do I need to replace anything like seals or bearings to make the straight shafts fit? The axle is pretty freshly rebuilt so seals and bearings should still be good. Thanks.
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    nope...just shove them in. they only taper in the center so nothing is affected.
  3. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    That's what I was hoping to hear, thanks for the info.
