Swapping for 3/4 tons?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nau81blazer, Nov 7, 2006.
  1. nau81blazer
    nau81blazer 1/2 ton status
    Mar 6, 2004
    329
    Cincinnati, OH
    Hey all,
    I know many of you have done this so I was wonder if you could help me. I might be getting ahold of some 3/4 running gear and was wonder what modifications would need to be made. I believe that they are out of a 74' k20. I'm going to be putting them into an 81' k5. Will the spring plates need to be moved? Will my steering bolt up to the new axle? Any modifications need to be made to brakes? Thanks for any input you can throw my way! :bow: :bow: :bow:
    --Adam
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The front axle is plug and play with the exception of the calipers, those will have a 7/16" banjo bolt instead of your 10mm banjo bolt so my suggestion is to unbolt your calipers and swing them out of the way and once the donor axle is swapped in bolt your calipers to it. The rear axle will be plug and play as well with the exception of the e-brake cables will be different but depending on the style of cables it has you might be able to use your existing ones over. The spring perches and shock mounts will all be correct but you will need the top plates and also a conversion u-joint.
  3. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yeah, and you'll need........um:confused: Nope! I guess that's about it:D
  4. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    I thought also new ubolts for the 14 bolt :D . I am getting ready to do the swap soon as well. :eek1:
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I would have hoped that would be a given but i was thinking i should have put that in there also. It would be someones luck to think they had everything needed for a weekend swap and once everything was out and the new stuff ready to install and all the 4x4 shops closed then they would find out they need new u-bolts as well.
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    new ubolts all the way around is a pretty good idea. be sure to buy plenty of gear oil, brake fluid.
    be sure you inspect the brakes.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Don't forget the new wheels . The 3/4 ton axles seem to have extra studs for some strange reason :wink1:
  8. nau81blazer
    Mar 6, 2004
    329
    Cincinnati, OH
    awesome!! Thanks for all the info guys!! The axles are in an existing vehicle so I'll make sure to get the u-bolts from him. The coversion joint can be purchased at NAPA right? thanks,
    -Adam
  9. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Or from a Vendor Right Here on CK5!:D
  10. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    Anybody have that NAPA part # handy for the conversion U-joint? Also, I though I read somewhere that the rear driveshaft has to be shortened due to the 14 bolt diff being larger (pushing the yoke farther forward than a 10 bolt's)? As soon as I get my 14 bolt back from the rebuild/Detroit install, I'll be tackling this same project.
  11. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i lost the part number, and im sure someone else on here will give it up, but in case not, just got o NAPA and look at 2 u-joints from the 14bff and the 10b and measure the endcaps, then they'll have a little book they match them up with to find the right part #. well i know the driveshaft will not have to be replaced if you have an np208 (slip-yoke) t-case. otherwise im not too sure.
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Just for reference , there are TWO np208 slip yoke driveshafts . One in 1310 with internal clips for the 81-82 trucks with 12 bolts , and one in s44/3r for some 82 and all 83 up trucks with 10 bolts .
    Either will fit the np208 , but each requires a different conversion joint to the 14bff 1350 .
    This threads starter just bought a 10 bolt shaft from me for a np208 and informed me he had internal clips on a 12 bolt , I said what year , he said 81 with stock 12 bolt . So he needs a conversion joint for even his 12 bolt .
  13. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    10 bolts have 1330 U joints
    12 bolts have 1310 U joints :D
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    10 bolts have s44/3r . Search button proves this , even though a well regarded member or two bought a truck with an aftermarket 1330 30 spline yoke :thumb:
  15. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Do NOT re-use the old u-bolts. Get new, much safer.
  16. nau81blazer
    Mar 6, 2004
    329
    Cincinnati, OH
    Thanks again for the hooking me up with that combo. I'm about to head to NAPA right now. Thanks again,
    --Adam
  17. filo
    filo Registered Member
    Mar 11, 2006
    96
    Anoka, Minnesota
    for the 10-bolt it is Napa part # 240-0358. (1330-1350) I apparently have the s44/3r and not the 1330.
    According to Four Wheeler Jun '04...1330 has 1 1/16" bearing cap diameter and the 1350 has 1 3/16" bearing cap diameter. It turns out the s44/3r has 1 1/8" diameter. Back to Napa I go.:doah:
