Swapping front clips
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LittlePig, Apr 13, 2001.
  1. LittlePig
    LittlePig 1/2 ton status
    Aug 9, 2000
    299
    East Texas
    One of the mods on my rig will be a clip swap, but reverse of what most do. I happen to like the pre-1980 round light style. I assume that if you can go from a pre-80 clip to a post-80 clip, you can go the other way too. Am I correct in thinking that it is merely a matter of replacing the hood, inner and outer fenders, grille and rad support? Is there any chance I can get away with keeping the support? I will be doing this to an ex-army blazer, which will have the heavy-duty radiator, and I am not sure if the brackets will be the same or not. Any input would be most appreciated. Thanks.
    Email: xiaozhu@my-deja.com
    ICQ: 84108805
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Should be easier than the other way around. You will have to change the core support...unless you fab up something.....way too much work. I did just the opposite on my '74 and I can't think of anything major that would be a problem. A/C condensor maybe...my old one would not work with the new core....Army Blazers probably don't have A/C anyway...Anyone else??
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  3. LittlePig
    Aug 9, 2000
    299
    East Texas
    Just curious, but why do you think going from new clip to old would be easier than old to new?
    ICQ: 84108805
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    You can get all the information you need from the write upp by Neil Picket on the main page under tecnichal. That should get you a good basis for understanding each step towards a complete front clip swap.
    heres a link:
    <A target="_blank" HREF=http://www.coloradok5.com/tech.shtml>http://www.coloradok5.com/tech.shtml</A>
    [​IMG] If your not living on the edge, your taking upp to much space![​IMG]
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    wiper pivots are different also.
    your right. I don't understand the jeep thing!
  6. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    First of all, are you talking just the Front grille or the whole clip??????? If you're talking the clip, Then your doors won't match from what I understand, You're in for a real big battle!
  7. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    the door shells are the same from 76-91. some of the Inner pieces changed, but the doors will work.
  8. Michael
    1,576
    Sherman, Texas
    When you go from early to late you have to cut holes in the firewall so your late model hinges will recess. When you go from late to early you won't have to do that....hence easier. Yout later style wiper posts might work or they might hit the hood...you'll just have to try it......they're not that tuff to swap out. I wouldn't do the change, but you probably wouldn't do some of the stuff I've done......ain't America great! Oh yeah...the doors make no difference at all.
    Michael[​IMG]
